I have a very short video I made using the latest version Active Presenter. When viewing it in the software, I was able to hear the audio portion of the recording.
However, even with “Export Audio” checked, I am unable to hear the audio when exported to MP4. Please help!
EDIT - LOG BELOW:
2018-01-03 16:24:53: ActivePresenter 7.0.0 (Release Build: 2017.12.28) started
OS: Windows 10 (build 16299), 64-bit edition. Version: 10.0 - 64 bit
CPU Count: 4
Computer Name: DESKTOP-41PQT17 (). Memory: 16,252 MB. Available: 11,140 MB. Memory Load: 31%
Project Location: C:\Users\mosel\Documents\ActivePresenter
Disk Space: 940,746 MB (Free: 450,826 MB)
2018-01-03 16:24:53: TempDir: C:\Users\mosel\AppData\Roaming\ActivePresenter\temp
2018-01-03 16:25:04: Checking updates for ActivePresenter v7.0.0…
2018-01-03 16:25:19: flt sample format is not supported, s16 will be used
2018-01-03 16:25:19: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:25:19: Preparing to record audio from: Microphone (Realtek Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2018-01-03 16:30:10: Start capturing. Mode: Full motion. Method: 0. Capture Size: (1920, 1080)
2018-01-03 16:30:10: Video Codec: flashsv. Expecting FPS: 30.00
2018-01-03 16:30:11: Video will be recorded to: C:\Users\mosel\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\video_20180103_16-30-10.mkv
2018-01-03 16:30:11: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:30:11: flt sample format is not supported, s16 will be used
2018-01-03 16:30:11: Audio will be recorded to: C:\Users\mosel\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\audio_20180103_16-30-11.wav
2018-01-03 16:30:11: Preparing to record audio from: Microphone (Realtek Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2018-01-03 16:30:11: Audio 2 will be recorded to: C:\Users\mosel\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\audio_20180103_16-30-11_1.wav
2018-01-03 16:30:11: Preparing to record audio from: Speakers / Headphones (Realtek Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2018-01-03 16:30:29: Stop video recording. Frames recorded: 457. Dropped: 0. Duration: 15226. Actual FPS: 29.95
2018-01-03 16:30:29: Recorded video data size: 20730 KB
2018-01-03 16:30:30: ProcessRecordedAudio: duration (ms) 15298.125000
2018-01-03 16:30:31: ProcessRecordedAudio: duration (ms) 15310.667000
2018-01-03 16:30:33: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:30:34: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:30:34: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:30:34: Audio Decode Stats: Process 16.000000, Wait 0.000000
2018-01-03 16:30:34: Audio Encoding Stats: Process 0.000000, Wait 16.000000
2018-01-03 16:30:34: Audio Decode Stats: Process 15.000000, Wait 0.000000
2018-01-03 16:30:34: Audio Encoding Stats: Process 15.000000, Wait 0.000000
2018-01-03 16:30:34: Audio Encoding Stats: Process 16.000000, Wait 0.000000
2018-01-03 16:30:35: Preparing to play audio to: Speakers / Headphones (Realtek Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2018-01-03 16:30:35: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:31:45: flt sample format is not supported, s16 will be used
2018-01-03 16:31:45: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:31:45: Preparing to record audio from: Speakers / Headphones (Realtek Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2018-01-03 16:31:49: Start capturing. Mode: Smart Capture. Method: 0. Capture Size: (1920, 1080)
2018-01-03 16:31:49: flt sample format is not supported, s16 will be used
2018-01-03 16:31:49: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:31:49: Audio 2 will be recorded to: C:\Users\mosel\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled1_tempdir\audio_20180103_16-31-49.wav
2018-01-03 16:31:49: Preparing to record audio from: Speakers / Headphones (Realtek Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2018-01-03 16:33:09: Video will be recorded to: C:\Users\mosel\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled1_tempdir\video_20180103_16-33-09.mkv
2018-01-03 16:33:09: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:33:12: Stop video recording. Frames recorded: 109. Dropped: 0. Duration: 3920. Actual FPS: 27.55
2018-01-03 16:33:13: Recorded video data size: 16605 KB
2018-01-03 16:33:23: Video will be recorded to: C:\Users\mosel\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled1_tempdir\video_20180103_16-33-23.mkv
2018-01-03 16:33:23: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:33:23: Stop video recording. Frames recorded: 5. Dropped: 0. Duration: 131. Actual FPS: 30.53
2018-01-03 16:33:23: Video duration is too small: 166 (ms)
2018-01-03 16:33:27: Video will be recorded to: C:\Users\mosel\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled1_tempdir\video_20180103_16-33-27.mkv
2018-01-03 16:33:27: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:33:35: Stop video recording. Frames recorded: 230. Dropped: 0. Duration: 8020. Actual FPS: 28.55
2018-01-03 16:33:35: Recorded video data size: 15987 KB
2018-01-03 16:33:54: Video will be recorded to: C:\Users\mosel\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled1_tempdir\video_20180103_16-33-54.mkv
2018-01-03 16:33:54: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:33:55: Stop video recording. Frames recorded: 25. Dropped: 0. Duration: 800. Actual FPS: 30.00
2018-01-03 16:33:55: Video duration is too small: 833 (ms)
2018-01-03 16:34:00: Video will be recorded to: C:\Users\mosel\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled1_tempdir\video_20180103_16-34-00.mkv
2018-01-03 16:34:00: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:34:01: Stop video recording. Frames recorded: 28. Dropped: 0. Duration: 931. Actual FPS: 29.00
2018-01-03 16:34:01: Video duration is too small: 966 (ms)
2018-01-03 16:34:02: Video will be recorded to: C:\Users\mosel\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled1_tempdir\video_20180103_16-34-02.mkv
2018-01-03 16:34:02: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:34:03: Stop video recording. Frames recorded: 18. Dropped: 0. Duration: 584. Actual FPS: 29.11
2018-01-03 16:34:03: Video duration is too small: 633 (ms)
2018-01-03 16:34:27: ProcessRecordedAudio: duration (ms) 155362.042000
2018-01-03 16:34:29: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:34:29: Audio Decode Stats: Process 110.000000, Wait 0.000000
2018-01-03 16:34:29: Audio Encoding Stats: Process 31.000000, Wait 79.000000
2018-01-03 16:34:29: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:34:41: Preparing to play audio to: Speakers / Headphones (Realtek Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2018-01-03 16:35:08: Preparing to play audio to: Speakers / Headphones (Realtek Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2018-01-03 16:35:44: flt sample format is not supported, s16 will be used
2018-01-03 16:35:44: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:35:44: Preparing to record audio from: Microphone (Realtek Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2018-01-03 16:35:49: flt sample format is not supported, s16 will be used
2018-01-03 16:35:49: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:35:49: Preparing to record audio from: Microphone (Realtek Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2018-01-03 16:36:07: Start capturing. Mode: Full motion. Method: 0. Capture Size: (1920, 1080)
2018-01-03 16:36:07: Video Codec: flashsv. Expecting FPS: 30.00
2018-01-03 16:36:07: Video will be recorded to: C:\Users\mosel\AppData\Roaming\ActivePresenter\temp\rl_20180103_163607_5udqser5xy_tempdir\video_20180103_16-36-07.mkv
2018-01-03 16:36:07: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:36:07: flt sample format is not supported, s16 will be used
2018-01-03 16:36:07: Audio will be recorded to: C:\Users\mosel\AppData\Roaming\ActivePresenter\temp\rl_20180103_163607_5udqser5xy_tempdir\audio_20180103_16-36-07.wav
2018-01-03 16:36:07: Preparing to record audio from: Microphone (Realtek Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2018-01-03 16:36:08: flt sample format is not supported, s16 will be used
2018-01-03 16:36:08: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:36:08: Audio 2 will be recorded to: C:\Users\mosel\AppData\Roaming\ActivePresenter\temp\rl_20180103_163607_5udqser5xy_tempdir\audio_20180103_16-36-07_1.wav
2018-01-03 16:36:08: Preparing to record audio from: Speakers / Headphones (Realtek Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2018-01-03 16:37:24: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:37:25: Preparing to play audio to: Speakers / Headphones (Realtek Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2018-01-03 16:37:21: Stop video recording. Frames recorded: 2069. Dropped: 0. Duration: 70358. Actual FPS: 29.39
2018-01-03 16:37:21: Recorded video data size: 97924 KB
2018-01-03 16:37:21: ProcessRecordedAudio: duration (ms) 70456.979000
2018-01-03 16:37:21: ProcessRecordedAudio: duration (ms) 70472.604000
2018-01-03 16:37:25: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:37:25: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:37:25: Audio Decode Stats: Process 79.000000, Wait 79.000000
2018-01-03 16:37:25: Audio Encoding Stats: Process 111.000000, Wait 47.000000
2018-01-03 16:37:25: Audio Decode Stats: Process 94.000000, Wait 0.000000
2018-01-03 16:37:25: Audio Encoding Stats: Process 24.000000, Wait 73.000000
2018-01-03 16:37:25: Audio Decode Stats: Process 89.000000, Wait 6.000000
2018-01-03 16:37:25: Audio Encoding Stats: Process 14.000000, Wait 81.000000
2018-01-03 16:37:32: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:39:14: flt sample format is not supported, s16 will be used
2018-01-03 16:39:14: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:39:14: Preparing to record audio from: Microphone (Realtek Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2018-01-03 16:39:38: Start capturing. Mode: Full motion. Method: 0. Capture Size: (1920, 1080)
2018-01-03 16:39:38: Video Codec: flashsv. Expecting FPS: 30.00
2018-01-03 16:39:38: Video will be recorded to: C:\Users\mosel\AppData\Roaming\ActivePresenter\temp\rl_20180103_163938_i1vax2dmiw_tempdir\video_20180103_16-39-38.mkv
2018-01-03 16:39:38: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:39:38: flt sample format is not supported, s16 will be used
2018-01-03 16:39:38: Audio will be recorded to: C:\Users\mosel\AppData\Roaming\ActivePresenter\temp\rl_20180103_163938_i1vax2dmiw_tempdir\audio_20180103_16-39-38.wav
2018-01-03 16:39:38: Preparing to record audio from: Microphone (Realtek Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2018-01-03 16:39:39: flt sample format is not supported, s16 will be used
2018-01-03 16:39:39: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:39:39: Audio 2 will be recorded to: C:\Users\mosel\AppData\Roaming\ActivePresenter\temp\rl_20180103_163938_i1vax2dmiw_tempdir\audio_20180103_16-39-38_1.wav
2018-01-03 16:39:39: Preparing to record audio from: Speakers / Headphones (Realtek Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2018-01-03 16:41:57: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:41:56: Stop video recording. Frames recorded: 3907. Dropped: 3. Duration: 133990. Actual FPS: 29.15
2018-01-03 16:41:56: Recorded video data size: 296063 KB
2018-01-03 16:41:56: ProcessRecordedAudio: duration (ms) 134089.083000
2018-01-03 16:41:56: ProcessRecordedAudio: duration (ms) 134090.083000
2018-01-03 16:41:58: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:41:58: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:41:58: Audio Decode Stats: Process 76.000000, Wait 1.000000
2018-01-03 16:41:58: Audio Encoding Stats: Process 44.000000, Wait 38.000000
2018-01-03 16:41:58: Preparing to play audio to: Speakers / Headphones (Realtek Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2018-01-03 16:41:58: Audio Decode Stats: Process 141.000000, Wait 0.000000
2018-01-03 16:41:58: Audio Encoding Stats: Process 47.000000, Wait 156.000000
2018-01-03 16:41:59: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:41:59: Audio Decode Stats: Process 140.000000, Wait 15.000000
2018-01-03 16:41:59: Audio Encoding Stats: Process 31.000000, Wait 156.000000
2018-01-03 16:41:59: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:46:09: RLMedia: MFT name: ‘H264 Encoder MFT’
2018-01-03 16:46:09: RLMedia: MF Setting Framerate: 30 / 1
2018-01-03 16:46:09: RLMedia: MF Setting Quality: 70
2018-01-03 16:46:09: RLMedia: MF Setting GOPSize: 90
2018-01-03 16:46:09: s32 sample format is not supported, fltp will be used
2018-01-03 16:46:09: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2018-01-03 16:50:41: RLMedia: Qavg: 29216.557
2018-01-03 16:50:41: RLMedia: 2 frames left in the queue on closing
2018-01-03 16:50:41: Exporting video completed in 271 seconds.
2018-01-03 16:46:46: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:46:48: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:47:43: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:47:44: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:49:42: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:49:43: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:49:58: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:49:59: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:50:39: Audio Decode Stats: Process 269836.000000, Wait 0.000000
2018-01-03 16:50:39: Audio Encoding Stats: Process 33134.000000, Wait 236729.000000
2018-01-03 16:50:40: Video Decode Stats: Process 263339.000000, Wait 7635.000000, Decode 218061.000000
2018-01-03 16:50:40: Video Encoding Stats: Process 58876.000000, Wait 212165.000000
2018-01-03 16:55:27: Preparing to play audio to: Speakers / Headphones (Realtek Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2018-01-03 16:55:28: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:56:03: Audio Decode Stats: Process 0.000000, Wait 0.000000
2018-01-03 16:56:03: Audio Encoding Stats: Process 0.000000, Wait 0.000000
2018-01-03 16:56:04: Audio Decode Stats: Process 100.000000, Wait 106.000000
2018-01-03 16:56:04: Audio Encoding Stats: Process 221.000000, Wait 0.000000
2018-01-03 16:56:05: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:56:05: Audio Decode Stats: Process 102.000000, Wait 609.000000
2018-01-03 16:56:05: Audio Encoding Stats: Process 667.000000, Wait 47.000000
2018-01-03 16:56:31: Video Decode Stats: Process 25817.000000, Wait 0.000000, Decode 7800.000000
2018-01-03 16:56:31: Video Encoding Stats: Process 7177.000000, Wait 18830.000000
2018-01-03 16:56:32: Audio Decode Stats: Process 72.000000, Wait 1035.000000
2018-01-03 16:56:32: Audio Encoding Stats: Process 1107.000000, Wait 2.000000
2018-01-03 16:56:32: Audio Decode Stats: Process 114.000000, Wait 185.000000
2018-01-03 16:56:32: Audio Encoding Stats: Process 315.000000, Wait 0.000000
2018-01-03 16:56:33: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:56:35: Audio Decode Stats: Process 322.000000, Wait 1409.000000
2018-01-03 16:56:35: Audio Encoding Stats: Process 1669.000000, Wait 51.000000
2018-01-03 16:57:27: Video Decode Stats: Process 53514.000000, Wait 184.000000, Decode 16750.000000
2018-01-03 16:57:27: Video Encoding Stats: Process 14671.000000, Wait 39317.000000
2018-01-03 16:57:29: Audio Decode Stats: Process 208.000000, Wait 1563.000000
2018-01-03 16:57:29: Audio Encoding Stats: Process 1786.000000, Wait 0.000000
2018-01-03 16:57:30: Audio Decode Stats: Process 208.000000, Wait 713.000000
2018-01-03 16:57:30: Audio Encoding Stats: Process 921.000000, Wait 0.000000
2018-01-03 16:57:30: Audio Decode Stats: Process 0.000000, Wait 215.000000
2018-01-03 16:57:30: Audio Encoding Stats: Process 246.000000, Wait 0.000000
2018-01-03 16:57:31: Audio Decode Stats: Process 12.000000, Wait 108.000000
2018-01-03 16:57:31: Audio Encoding Stats: Process 124.000000, Wait 0.000000
2018-01-03 16:57:31: Audio Decode Stats: Process 0.000000, Wait 199.000000
2018-01-03 16:57:31: Audio Encoding Stats: Process 199.000000, Wait 0.000000
2018-01-03 16:57:31: Audio Decode Stats: Process 9.000000, Wait 4.000000
2018-01-03 16:57:31: Audio Encoding Stats: Process 15.000000, Wait 1.000000
2018-01-03 16:57:32: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:57:32: Audio Decode Stats: Process 38.000000, Wait 63.000000
2018-01-03 16:57:32: Audio Encoding Stats: Process 85.000000, Wait 31.000000
2018-01-03 16:57:34: Video Decode Stats: Process 1787.000000, Wait 100.000000, Decode 697.000000
2018-01-03 16:57:34: Video Encoding Stats: Process 635.000000, Wait 1279.000000
2018-01-03 16:57:34: Audio Decode Stats: Process 0.000000, Wait 47.000000
2018-01-03 16:57:34: Audio Encoding Stats: Process 65.000000, Wait 0.000000
2018-01-03 16:57:34: Audio Decode Stats: Process 0.000000, Wait 0.000000
2018-01-03 16:57:34: Audio Encoding Stats: Process 17.000000, Wait 0.000000
2018-01-03 16:57:35: Audio Decode Stats: Process 16.000000, Wait 31.000000
2018-01-03 16:57:35: Audio Encoding Stats: Process 51.000000, Wait 0.000000
2018-01-03 16:57:35: Audio Decode Stats: Process 0.000000, Wait 31.000000
2018-01-03 16:57:35: Audio Encoding Stats: Process 31.000000, Wait 0.000000
2018-01-03 16:57:35: Audio Decode Stats: Process 0.000000, Wait 48.000000
2018-01-03 16:57:35: Audio Encoding Stats: Process 48.000000, Wait 2.000000
2018-01-03 16:57:36: Audio Decode Stats: Process 16.000000, Wait 16.000000
2018-01-03 16:57:36: Audio Encoding Stats: Process 32.000000, Wait 0.000000
2018-01-03 16:57:36: Audio Decode Stats: Process 32.000000, Wait 0.000000
2018-01-03 16:57:36: Audio Encoding Stats: Process 16.000000, Wait 16.000000
2018-01-03 16:57:37: RLMedia: Estimating duration from bitrate, this may be inaccurate
2018-01-03 16:57:37: Audio Decode Stats: Process 47.000000, Wait 84.000000
2018-01-03 16:57:37: Audio Encoding Stats: Process 100.000000, Wait 31.000000
2018-01-03 16:57:40: Video Decode Stats: Process 3054.000000, Wait 0.000000, Decode 949.000000
2018-01-03 16:57:40: Video Encoding Stats: Process 765.000000, Wait 2313.000000
2018-01-03 16:57:40: Audio Decode Stats: Process 16.000000, Wait 62.000000
2018-01-03 16:57:40: Audio Encoding Stats: Process 78.000000, Wait 0.000000
2018-01-03 16:57:40: Audio Decode Stats: Process 56.000000, Wait 58.000000
2018-01-03 16:57:40: Audio Encoding Stats: Process 118.000000, Wait 0.000000
2018-01-03 16:57:40: Audio Decode Stats: Process 13.000000, Wait 98.000000
2018-01-03 16:57:40: Audio Encoding Stats: Process 111.000000, Wait 2.000000
2018-01-03 16:57:40: Audio Decode Stats: Process 8.000000, Wait 0.000000
2018-01-03 16:57:40: Audio Encoding Stats: Process 16.000000, Wait 0.000000
2018-01-03 16:57:41: Audio Decode Stats: Process 2.000000, Wait 5.000000
2018-01-03 16:57:41: Audio Encoding Stats: Process 10.000000, Wait 2.000000
2018-01-03 16:57:41: Audio Decode Stats: Process 2.000000, Wait 20.000000
2018-01-03 16:57:41: Audio Encoding Stats: Process 22.000000, Wait 0.000000
2018-01-03 16:57:41: Audio Decode Stats: Process 40.000000, Wait 30.000000
2018-01-03 16:57:41: Audio Encoding Stats: Process 69.000000, Wait 0.000000
