This is my first post and I don’t know how to que or step the slide changes while recording the narration audio and the screen. Am I required to record the narration first and then add the slides or can I record them at the same time as one package? I simply want to record my slides and narration audio as if I were presenting.
You just need to create the slides first, then record the narration. The recorded narration will be displayed as a separate object in the timeline pane. If you are not satisfied with the narration, you can easily delete it and record again.
For more information, please refer to this tutorial:
