I start with Saola Animate, I want the DIV_3 tag to be the child of DIV-2, how should I do?
You can’t make Div_3 to be a child of Div_2 because only Group elements can contain other elements.
In your case, you can select both Div_2 and Div_3 on Canvas, right-click and select Group from the context menu. After that, you can decorate the group as Div_2 and delete Div_2.
In the next version, Saola Animate will allow grouping just only one element so creating nested elements will become more convenient.
Thenk’s for your reply
