Problem: unable to insert shapes and symbols in recording
ActivePresenter version:
OS:
OS:
Hi Manish,
Could you please describe your issue in detail so that we we can understand it better.
Dear Team,
I want to point out any particular topics or content during recording as in circle or rectangle shape.
Please suggest in this regard.
can i add these shapes after recording???
Hi Manish,
Yes, it is very easy to add more callouts to any particular part or content when finish recording.
You can insert a shape then style it in the Format tab or in its Properties pane.
Please refer to this article to get useful information:
Moreover, it is possible to save your customized shape and reuse later in other projects. Object Templates will help you do that.
Feel free to take a closer look at this article:
Best regards,
Team,
Actually when i will do screen recording then how will able to point out with shapes.
After recording, you can freely edit your recorded video.
We cannot add any callouts while recording, unfortunately.
