For some reasons unknown to me, the navigaton bar is not responding. Would anyone have suggestions to solve this problem? Or am I missing something else?
Navigation bar.approj (460 KB)
I have checked the project and found that this is because you have not set the Navigation setting for the project.
So, to change the setting, go to Export tab > Player Settings > Content > Navigation > Free > then Apply.
I hope the information helps.
BR,
Quỳnh Anh
Thank you, it did work well!
