Hello,
I used to be able to have AP6 and AP7 installed in parallel.
Now that I installed 8 it seems it removed my 7 and 6 installations regardless of my clicking no to the remove part.
I now tried to reinstall 7 as I need to keep some projects in this format and it removes 8… I cannot change the installation folder. I guess I could install 8 - rename the folder and then install 7 - but I would need to redo this at every update.
Or did I miss something?
Michael
Hi Michael,
Installing multiple versions of AP is not officially supported but I think you should copy the version 7 to other location, just keep the version 8 in the original installed folder because it is most frequently updated.
of course. Logical. I will do that - thanks,
