Problem: If I create a multiple choice question ( example - 3 correct choices ) , how can I control the correct number of choice selection ( 3 checks ) ?
The number of choices must match the number of clicks/checks by the user.
I am not sure that I understand your question correctly. The multiple choice question has only one answer (check). Can you please explain the problem more clearly?
Unfortunately, the current version doesn’t allow limiting the
number of choices. (The number of answers that user can check doesn’t depend on the number of correct answers).
