Problem: When using a WEBM movie that includes an alpha channel the movie displays very poorly (i.e. digital noise or badly broken up) or not all in the designer. The movie plays correctly when the scene is tested. The movie also doesn’t scrub at all when moving the playhead.
Saola Animate version: Required.
2.7.1
OS: Required.
Windows
We tested this with a full frame movie. If we render the movie as WEBM with no alpha then it works fine in the designer and at playout. With ALPHA present it does not display in the designer.
The file is
sample file
