Seems like I’m asking one question after another, and I so appreciate the kind and helpful help I’ve been getting.
My current problem is to move the location of a “Sorry your answer is not correct” box to a location based on the location of another text box (essentially above it a short distance), then display it.
With my limited knowledge of JavaScript it looks like I need to do something like the following:
// Set variable {left} to the left position of my text box
var left = prez.object(‘txtMyBox’).left();
// Set variable {top} to the left position of my text box
var top = prez.object(‘txtMyBox’).top();
//Offset {top} variable to become a bottom position for the “sorry” box above it
var bot = top - 3;
//Move “Sorry” box to location by variables
prez.object(‘txtSorry’).left(left);
prex.object(‘txtSorry’).bot(bot);
//Show the box
prez.object(‘txtSorry’).show();
I know this is terribly wrong because it simply doesn’t work and I’m just learning Javascript (day 3). Suggestions?
Roger
