Recently i purchased active presenter 8 and the application is being used for the software documentation purpose. Now i don’t want any annotation box and it is disabled. however i would like to capture when mouse click location highlight with round circle or similar like that , is there any feature like that in activepresenter.
Thanks for your interest in ActivePresenter!
When recording video demonstration or software simulations, you can disable all the annotation and mouse click interaction as you want.
To get it done, open the Record Settings dialog by clicking (1) > Annotation tab > clear Annotation and Mouse Click Interaction check box (2) > Save.
Please see the attach image for more information.
Besides, you can capture with cursor highlight by opening the Cursor tab > select the (3) check boxes in the Cursor Settings section.
After recording, you can change the mouse cursor as well. Check out the article Change Mouse Cursor and Mouse Clicks in Captured Videos for more details.
Best Regards,
