Active presenter cant use my microphone even though all other programs can, and I had no problems just a week ago! I’ve restarted, updated and checked the permissions. Nothing helps!
What can I do?
ActivePresenter version: Version 8.5.8 - 64-bit build
The microphone works fine, just not with ActivePresenter. Everything is restarted and updated. I have a different microphone (headset) and that one works with AP.
Can you guys please share the log of ActivePresenter so we can check? To view the log, click ActivePresenter > Preferences > Miscellaneous > View Log.
In case the log is too long and you can not upload here, please save it as a file and send it to us at email support@atomisystems.com.
Hi @Tuyenluu, here it goes, can’t upload files because I’m new but I give you a pastebin link with my logs (Pastebin ActivePresenter Logs). Thanks and wait for a reply.
