Hi
I encountered the above bug.
I set attemps to 3 times. It is OK to choose different wrong answer but the slide freezed if I choose the same wrong answer.
I can still continue the tutorial by click the next slide button but I cannot re-attempt the MCQ question again.
Thanks
We can’t reproduce this issue in our tests.
Please share your project to support@atomisystems.com so that we can check.
You can delete all slides except the one with the MCQ.
Problem solved by myself
Thank you
