Hi, Just found MCQ button and response feedback turned to CHinese automatically.
I want English and how should I set them back to English by default.
Thanks
Thanks
I am not sure that I understand your problem correctly. Can you please provide a screenshot for the issue?
Seems you are using the Chinese language interface. Please switch ActivePresenter to English interface by going to View -> Language.
Please notice that only applies to new projects. For existing projects, you should translate it manually.
Thanks. That solved my problem.
