Hi Mike,
To insert a footer in your project, in the Insert tab > click Footer > type text in the Footer box. For more information, please refer to this tutorial:
When using slide master to insert footer, please make sure to insert exactly the slide layout that you have customized in the Slide Master View to your project.
More information about Slide Master:
Do you understand what I mean? (I already read the documentation)
We create a new slide based on a master slide. And we want the text (“More than one answer can be correct …”) of the masterslide textfield to appear in every new slide.
But unfortunately the textfield is empty.
How can we make the textfield keep the entered text?
A Button keeps the entered text (“Next Challenge”).
Ok, I understand now. Thank you for clarifying the issue.
Actually, the placeholder is working as designed. Its function is just for adding a placeholder to the slide, and you have to adjust it manually in the normal view. (e.g. adding content to it like text, images,…).
In this case, if you want the text to appear in every new slide, you should insert a shape instead of a placeholder and type text into it.
