I have a challenge that I have many text boxes and images to be loaded on click based on buttons.
Example:
Say I have 10 text boxes and 10 buttons. if I click 1 button, relevant text box will appear. 9 text boxes will have to be hidden. So I have to write 10 on click actions (crude way). If you consider same logic for all 10 buttons and text boxes. the code written for a particular slide would be 100 times (10 code lines x 10 buttons). Complexity gets added when I use shapes to highlight important areas and also load images. Grouping them is a solution but memory and browser processing is a problem.
Need to find simpler logic to do this. What happens is if I click buttons quite fast (considering mischievous user), browser gets hung and nothing can be displayed.
Possible solutions?
Have some JavaScript code written to handle this. I cannot do it as I don’t know coding. Please help if you have one in stock or can help write one and I can then tweak it bit to suit my requirement.
Place 10 text boxes on same layer (say at every 5 seconds on timeline) and give some code which will stop at a particular time (seconds). This will help manage the browser processing and memory quite well. The question is what code/option needs to be used in such case.
Thanks in advance.
Shri
