Making a labyrinth
I’m trying to make a labyrinth and I’m having troubles to find when a object touch other object, like the walls or some object that the user should to find.
Does someone do something similar? Some suggestion?
Thank you !
ActivePresenter version: 8
OS: windows 10
Hi Pedro,
Could you please send your project and describe what you want to achieve in detail?
It may help us understand your issue clearly. Thanks to that we can support you better.
Yen
Thank you for your faster reply.
I think that I’ve solved the problem. It wasn’t about ActivePresenter but about data structures hah
Thank you again.
