I try to make a slider which on position 1 shows nothing or hides everything, on position 2 shows text 1 and on position 3 hides text 1 and shows text 2.
How can I build this?
Thanks for your help!
Mel
Mel
Hi Mel,
You can totally do that in ActivePresenter.
Here is the sample I’ve made for you:
Slider sample.approj (304 KB)
You can watch this quick tutorial I’ve recorded here for more information:
On the screen is after you have added the slider and the information.
The workaround here is to use Advanced Action to group actions together.
Thus, whenever you move the thumb to each position, those actions will happen at the same time.
Besides, we have already made a detailed tutorial for a more complex project.
You can take a look if needed later:
Feel free to follow up with me if there’s anything unclear.
BR,
Hi! You are awesome! Thank you very much!
A suggestion from me: maybe you can put this information on your sliders page “How to Work with Sliders in ActivePresenter 9”. I couldn’t find this and the other youtube video you linked in your reply. Best regards!
Thank you for your suggestion.
I will add them at the end of the video and tutorial.
Let me know if you need any other assistance.
Quynh Anh
