Hello,
I have two slides.
On the first slide there is an object the state of which is ‘invisible’.
On the second slide, there is a button. If I click on that button, I want it to open the first slide at a specific timestamp and to show that invisible object, so to set the state ‘visible’.
I managed that the slide opens at the time I wish, but I do not get the object to show.
Where is my mistake?
(I am only a Newbie to Javascript.)
prez.showSlide(‘Slide1’);
prez.slideTime (95000);
prez.object(‘shape’).show(); //does not work
prez.object(‘shape’).visible(); //does not work
Augustin
ActivePresenter version: 8
OS: Win10
