Is it possible to maintain the zoom/pan position across a slide break? I have a long explanation and it will be useful to split it across several slides - to make it easier for students to quickly jump to the right bits when it is saved as html5.
I’m demonstrating some excel functions, so I have zoomed in to a portion of a spreadsheet for part of the explanation, so it is easier to see what I type.
But,if I introduce slide breaks in this section, the zoo/pan resets to full slide view on the new slide. Is it possible to maintain a zoom across a slide break?
Kind regards,
David
