Recorded video; no issues with play back. Copied sections of video and overlayed it; no issues with play back. Added blur; it hangs on playback and I have to kill Active Presenter. I tried to upload a log, but it says new users cannot upload log file. So I copied part of the log into the notes section below.
ActivePresenter version: 8.3.2 64-bit build released 2021.01.26 (licensed)
OS: Mac Catalina 10.15.7 Intel Core i7
2021-06-11 14:43:29: ActivePresenter 8.3.2 - 64-bit build. (Release Build: 2021.01.26) started
OS: macOS Catalina Version 10.15.7 (Build 19H1217)
CPU Count: 12
Hostname: REWMB0558. Memory: 14,912 MB. Available: 6,648 MB. Memory Load: 55%
Disk Space: 239,072 MB (Free: 156,910 MB)
Project Location: /Users/tjbald/Documents/ActivePresenter/
2021-06-11 14:43:29: TempDir: /Users/tjbald/Library/Application Support/ActivePresenter/temp
2021-06-11 14:43:34: Opening project: /Users/tjbald/Documents/ActivePresenter/ThisOneHangs.approj
2021-06-11 14:43:34: PrepareRibbonBar: 437ms
2021-06-11 14:43:35: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-06-11 14:43:36: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-06-11 14:45:01: Render Project Size: 1179 x 693
2021-06-11 14:45:01: Threads Used: 6 / 12, Memory Available: 6,223/14,912
2021-06-11 14:45:01: Preparing to play audio to: PowerConf S3. Channel: 2. Sample rate: 48000. Sample Format: 8
2021-06-11 14:45:01: Audio frames decoding started.
2021-06-11 14:45:01: Video frames decoding started.
2021-06-11 14:45:01: No media stream found!
2021-06-11 14:45:06: 104f35af-6709-4c2f-918c-9ec60b1537fe: Seek after: 15.000000
