Thanks for contacting us.
For your concern, ActivePresenter stores large audio/video resources of a project in an external data folder named PROJECT_FILE_files.
Therefore, if this is the case, when you open your project, please make sure that the project is sent together with its external data folder.
The issue might happen when you rename, move or copy the project file without doing the same with its external data folder.
You can have a look at the video below for more details:
How to Send Projects with External Data Folders - ActivePresenter 8 - YouTube
If that’s not the case, could you kindly let us know if you have editted the video you lost? Please also share the log of ActivePresenter so we can check.
To view the log, click ActivePresenter > Preferences > Miscellaneous > View Log.
Look forward to your update.
Kind regards,
Quynh Anh
