Problem: When I added “Text to Speech” audio, why there is only 1 available microsoft voice in my active presenter. Is there any possible way to have another microsoft voice?
ActivePresenter Version: 7.0
OS: Hp Windows 7
OS: Hp Windows 7
Hi Hannah,
Thanks for your question!
ActivePresenter loads any SAPI5 compatible voices installed on your computer. Hence, if you want to add more text-to-speech voices, you can install any SAPI5 compatible voices on your computer. Then, ActivePresenter will detect and load it automatically.
Yen
Thank you ! Problem solved.
