Hello, while I was recording a video, my laptop crashed and I lost the recording. I searched on the Log, the info is below. I also checked for the cached files, there was nothing there. A message was shown, autosaved has saved the video but it is only 3 seconds long. Please help me recover it.
2023-03-21 17:14:05: ActivePresenter 9.0.7 - 64-bit build. (Release Build: 2023.03.15) started
OS: Windows 10 (build 19044), 64-bit edition
CPU Count: 4
Hostname: DESKTOP-1M8BFFT. Memory: 8,057 MB. Available: 1,997 MB. Memory Load: 75%
Disk Space: 230,799 MB (Free: 4,635 MB)
Project Location: C:\Users\micha\OneDrive\Documents\ActivePresenter
2023-03-21 17:14:05: TempDir: C:\Users\micha\AppData\Roaming\ActivePresenter\temp
2023-03-21 17:14:05: -----------------LISTING GRAPHICS DEVICES---------------------
2023-03-21 17:14:05: DXGIAdapter: Intel(R) HD Graphics 620 (0-93612)
2023-03-21 17:14:05: * \.\DISPLAY1 [0, 0, 1920, 1080], 1
2023-03-21 17:14:05: DXGIAdapter: Microsoft Basic Render Driver (0-94454)
2023-03-21 17:14:05: Selected DXGIAdapter: Intel(R) HD Graphics 620 (0-93612).
2023-03-21 17:14:05: --------------------------------------------------------------
2023-03-21 17:14:09: ---------------------LISTING AUDIO DEVICES------------------------
2023-03-21 17:14:09: Ηχεία / Ακουστικά (Realtek Audio) (API: Windows WASAPI, Input: 2, Output: 2, Rate: 48000, Loopback: true, Default Output: true, ID: {0.0.0.00000000}.{b85eabe7-0b33-4d5a-929e-349346bd4201})
2023-03-21 17:14:09: Μικρόφωνο (Realtek Audio) (API: Windows WASAPI, Input: 2, Output: 0, Rate: 48000, Loopback: false, Default Output: false, ID: {0.0.1.00000000}.{3fc9f6fc-77c1-450b-8f40-bdd8a5177f29})
2023-03-21 17:14:09: --------------------------------------------------------------
2023-03-21 17:14:11: ---------------------LISTING WEBCAMS------------------------
2023-03-21 17:14:11: 1. Integrated Webcam - \?\usb#vid_0bda&pid_5769&mi_00#6&1ff99936&2&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
2023-03-21 17:14:11: --------------------------------------------------------------
2023-03-21 17:14:16: PrepareRibbonBar: 3215ms
2023-03-21 17:14:17: MKAudioRecorder::Open: Device: {0.0.1.00000000}.{3fc9f6fc-77c1-450b-8f40-bdd8a5177f29}, File: C:\Users\micha\AppData\Roaming\ActivePresenter\temp\rl_20230321_171417_02cyikc1xx.wav, Params: codec: 0, format: Sample Format 5, channel: 2, frame_size: 0, rate: 48000.000000, bit_rate: 0, quality: 90
2023-03-21 17:14:17: Probing to record audio from: Μικρόφωνο (Realtek Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 1
2023-03-21 17:14:18: Open audio device successes!
2023-03-21 17:14:18: flt sample format is not supported, s16 will be used
2023-03-21 17:14:33: Start capturing. Mode: Full motion. Capture Size: (1920, 1080)
2023-03-21 17:14:33: MKScreenRecorder::Open: Engine:2, File: C:\Users\micha\OneDrive\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\video_20230321_17-14-33.mp4, Params: codec: 10001, format: NV12, width: 1920, height: 1080, color_range: 8, rate: 30.000000, bit_rate: 0, quality: 90
2023-03-21 17:14:33: Encoder: - h264_mf
2023-03-21 17:14:33: MKAudioRecorder::Open: Device: {0.0.1.00000000}.{3fc9f6fc-77c1-450b-8f40-bdd8a5177f29}, File: C:\Users\micha\OneDrive\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\audio_1_20230321_17-14-33.wav, Params: codec: 0, format: Sample Format 5, channel: 2, frame_size: 0, rate: 48000.000000, bit_rate: 0, quality: 90
2023-03-21 17:14:33: Probing to record audio from: Μικρόφωνο (Realtek Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 1
2023-03-21 17:14:33: Open audio device successes!
2023-03-21 17:14:33: flt sample format is not supported, s16 will be used
2023-03-21 17:14:33: MKAudioRecorder::Open: Device: {0.0.0.00000000}.{b85eabe7-0b33-4d5a-929e-349346bd4201}, File: C:\Users\micha\OneDrive\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\audio_2_20230321_17-14-33.wav, Params: codec: 0, format: Sample Format 5, channel: 2, frame_size: 0, rate: 48000.000000, bit_rate: 0, quality: 90
2023-03-21 17:14:33: Probing to record audio from: Ηχεία / Ακουστικά (Realtek Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 1
2023-03-21 17:30:36: MKScreenCaptureD2DImpl:StopCapture Frame: 15551, Drop: 67, Encoded FPS 16.216550, Captured FPS 16.217593, Time: 958.896919s
2023-03-21 17:30:36: Recorded video data size: 133.4 MB
2023-03-21 17:30:36: ProcessRecordedAudio: duration (ms) 959459
2023-03-21 17:30:36: ProcessRecordedAudio: duration (ms) 959576
2023-03-21 17:30:39: Checking updates for ActivePresenter v9.0.7…
2023-03-21 17:31:59: Render Project Size: 1920 x 1080
2023-03-21 17:31:59: Threads Used: 1 / 4, Memory Available: 1,808/8,057
2023-03-21 17:31:59: Probing to play audio from: Ηχεία / Ακουστικά (Realtek Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 8
2023-03-21 17:31:59: Open audio device successes!
2023-03-21 17:32:21: Render Project Size: 1920 x 1080
2023-03-21 17:32:21: Threads Used: 1 / 4, Memory Available: 1,553/8,057
2023-03-21 17:32:21: Probing to play audio from: Ηχεία / Ακουστικά (Realtek Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 8
2023-03-21 17:32:22: Open audio device successes!
2023-03-21 17:34:16: ActivePresenter 9.0.7 (Release Build: 2023.03.15) shut down
2023-03-21 17:35:38: ActivePresenter 9.0.7 - 64-bit build. (Release Build: 2023.03.15) started
CPU Count: 4
Hostname: DESKTOP-1M8BFFT. Memory: 8,057 MB. Available: 2,792 MB. Memory Load: 65%
Disk Space: 230,799 MB (Free: 4,102 MB)
2023-03-21 17:35:38: TempDir: C:\Users\micha\AppData\Roaming\ActivePresenter\temp
2023-03-21 17:35:38: -----------------LISTING GRAPHICS DEVICES---------------------
2023-03-21 17:35:38: DXGIAdapter: Intel(R) HD Graphics 620 (0-93612)
2023-03-21 17:35:38: * \.\DISPLAY1 [0, 0, 1920, 1080], 1
2023-03-21 17:35:38: DXGIAdapter: Microsoft Basic Render Driver (0-94454)
2023-03-21 17:35:38: Selected DXGIAdapter: Intel(R) HD Graphics 620 (0-93612).
2023-03-21 17:35:38: --------------------------------------------------------------
2023-03-21 17:35:38: ---------------------LISTING AUDIO DEVICES------------------------
2023-03-21 17:35:38: Ηχεία / Ακουστικά (Realtek Audio) (API: Windows WASAPI, Input: 2, Output: 2, Rate: 48000, Loopback: true, Default Output: true, ID: {0.0.0.00000000}.{b85eabe7-0b33-4d5a-929e-349346bd4201})
2023-03-21 17:35:38: Μικρόφωνο (Realtek Audio) (API: Windows WASAPI, Input: 2, Output: 0, Rate: 48000, Loopback: false, Default Output: false, ID: {0.0.1.00000000}.{3fc9f6fc-77c1-450b-8f40-bdd8a5177f29})
2023-03-21 17:35:40: ---------------------LISTING WEBCAMS------------------------
2023-03-21 17:35:40: 1. Integrated Webcam - \?\usb#vid_0bda&pid_5769&mi_00#6&1ff99936&2&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
2023-03-21 17:35:40: --------------------------------------------------------------
2023-03-21 17:35:42: Opening project: C:\Users\micha\OneDrive\Desktop\first recording activepresenter.approj
2023-03-21 17:35:44: PrepareRibbonBar: 1510ms
2023-03-21 17:36:09: Render Project Size: 1920 x 1080
2023-03-21 17:36:09: Threads Used: 1 / 4, Memory Available: 2,338/8,057
2023-03-21 17:36:09: Encoder: Windows Media Foundation - h264_mf
2023-03-21 17:45:48: MKAudioRecorder::Open: Device: {0.0.1.00000000}.{3fc9f6fc-77c1-450b-8f40-bdd8a5177f29}, File: C:\Users\micha\AppData\Roaming\ActivePresenter\temp\rl_20230321_174548_aj6u66vukl.wav, Params: codec: 0, format: Sample Format 5, channel: 2, frame_size: 0, rate: 48000.000000, bit_rate: 0, quality: 0
2023-03-21 17:45:48: Probing to record audio from: Μικρόφωνο (Realtek Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 1
2023-03-21 17:45:48: Open audio device successes!
2023-03-21 17:45:48: flt sample format is not supported, s16 will be used
2023-03-21 17:45:53: Start capturing. Mode: Full motion. Capture Size: (1920, 1080)
2023-03-21 17:45:53: MKScreenRecorder::Open: Engine:2, File: C:\Users\micha\OneDrive\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\video_20230321_17-45-53.mp4, Params: codec: 10001, format: NV12, width: 1920, height: 1080, color_range: 8, rate: 30.000000, bit_rate: 0, quality: 90
2023-03-21 17:45:53: Encoder: - h264_mf
2023-03-21 17:45:53: MKAudioRecorder::Open: Device: {0.0.1.00000000}.{3fc9f6fc-77c1-450b-8f40-bdd8a5177f29}, File: C:\Users\micha\OneDrive\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\audio_1_20230321_17-45-53.wav, Params: codec: 0, format: Sample Format 5, channel: 2, frame_size: 0, rate: 48000.000000, bit_rate: 0, quality: 0
2023-03-21 17:45:53: Probing to record audio from: Μικρόφωνο (Realtek Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 1
2023-03-21 17:45:53: Open audio device successes!
2023-03-21 17:45:53: flt sample format is not supported, s16 will be used
2023-03-21 17:45:53: MKAudioRecorder::Open: Device: {0.0.0.00000000}.{b85eabe7-0b33-4d5a-929e-349346bd4201}, File: C:\Users\micha\OneDrive\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\audio_2_20230321_17-45-53.wav, Params: codec: 0, format: Sample Format 5, channel: 2, frame_size: 0, rate: 48000.000000, bit_rate: 0, quality: 0
2023-03-21 17:45:53: Probing to record audio from: Ηχεία / Ακουστικά (Realtek Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 1
2023-03-21 19:03:11: MKScreenCaptureD2DImpl:StopCapture Frame: 21746, Drop: 0, Encoded FPS 4.691492, Captured FPS 4.691707, Time: 4634.986343s
2023-03-21 19:03:12: Recorded video data size: 127.8 MB
2023-03-21 19:03:12: ProcessRecordedAudio: duration (ms) 4635617
2023-03-21 19:03:12: ProcessRecordedAudio: duration (ms) 4633711
2023-03-21 19:03:47: Render Project Size: 1920 x 1080
2023-03-21 19:03:47: Threads Used: 1 / 4, Memory Available: 2,791/8,057
2023-03-21 19:03:47: Encoder: Windows Media Foundation - h264_mf
2023-03-21 19:52:07: Exporting video completed in 2900 seconds.
2023-03-21 20:28:56: Error: can’t write to file descriptor 20 (error 112: There is not enough space on the disk.)
2023-03-21 20:28:56: Error while writing on destination file
2023-03-21 20:29:37: Error: can’t write to file descriptor 20 (error 112: There is not enough space on the disk.)
2023-03-21 20:29:37: Error while writing on destination file
2023-03-21 20:29:46: Error: can’t write to file descriptor 20 (error 112: There is not enough space on the disk.)
2023-03-21 20:29:46: Error while writing on destination file
2023-03-21 20:29:57: Error: can’t write to file descriptor 20 (error 112: There is not enough space on the disk.)
2023-03-21 20:29:57: Error while writing on destination file
2023-03-21 20:30:31: Error: can’t write to file descriptor 8 (error 112: There is not enough space on the disk.)
2023-03-21 20:30:31: Error while writing on destination file
2023-03-21 20:30:45: ActivePresenter 9.0.7 (Release Build: 2023.03.15) shut down
2023-03-28 17:26:42: ActivePresenter 9.0.7 - 64-bit build. (Release Build: 2023.03.15) started
CPU Count: 4
Hostname: DESKTOP-1M8BFFT. Memory: 8,057 MB. Available: 2,945 MB. Memory Load: 63%
Disk Space: 230,799 MB (Free: 5,815 MB)
2023-03-28 17:26:42: TempDir: C:\Users\micha\AppData\Roaming\ActivePresenter\temp
2023-03-28 17:26:42: -----------------LISTING GRAPHICS DEVICES---------------------
2023-03-28 17:26:42: DXGIAdapter: Intel(R) HD Graphics 620 (0-76623)
2023-03-28 17:26:42: * \.\DISPLAY1 [0, 0, 1920, 1080], 1
2023-03-28 17:26:42: DXGIAdapter: Microsoft Basic Render Driver (0-81087)
2023-03-28 17:26:42: Selected DXGIAdapter: Intel(R) HD Graphics 620 (0-76623).
2023-03-28 17:26:42: --------------------------------------------------------------
2023-03-28 17:26:42: ---------------------LISTING AUDIO DEVICES------------------------
2023-03-28 17:26:42: Ηχεία / Ακουστικά (Realtek Audio) (API: Windows WASAPI, Input: 2, Output: 2, Rate: 48000, Loopback: true, Default Output: true, ID: {0.0.0.00000000}.{b85eabe7-0b33-4d5a-929e-349346bd4201})
2023-03-28 17:26:42: Μικρόφωνο (Realtek Audio) (API: Windows WASAPI, Input: 2, Output: 0, Rate: 48000, Loopback: false, Default Output: false, ID: {0.0.1.00000000}.{3fc9f6fc-77c1-450b-8f40-bdd8a5177f29})
2023-03-28 17:26:44: ---------------------LISTING WEBCAMS------------------------
2023-03-28 17:26:44: 1. Integrated Webcam - \?\usb#vid_0bda&pid_5769&mi_00#6&1ff99936&2&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
2023-03-28 17:26:44: --------------------------------------------------------------
2023-03-28 17:26:49: PrepareRibbonBar: 2283ms
2023-03-28 17:27:21: Checking updates for ActivePresenter v9.0.7…
2023-03-28 17:36:27: MKAudioRecorder::Open: Device: {0.0.1.00000000}.{3fc9f6fc-77c1-450b-8f40-bdd8a5177f29}, File: C:\Users\micha\AppData\Roaming\ActivePresenter\temp\rl_20230328_173627_imx0qv1bvk.wav, Params: codec: 0, format: Sample Format 5, channel: 2, frame_size: 0, rate: 48000.000000, bit_rate: 0, quality: 0
2023-03-28 17:36:27: Probing to record audio from: Μικρόφωνο (Realtek Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 1
2023-03-28 17:36:27: Open audio device successes!
2023-03-28 17:36:28: flt sample format is not supported, s16 will be used
2023-03-28 17:36:31: Start capturing. Mode: Full motion. Capture Size: (1920, 1080)
2023-03-28 17:36:32: MKScreenRecorder::Open: Engine:2, File: C:\Users\micha\OneDrive\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled1_tempdir\video_20230328_17-36-32.mp4, Params: codec: 10001, format: NV12, width: 1920, height: 1080, color_range: 8, rate: 30.000000, bit_rate: 0, quality: 90
2023-03-28 17:36:32: Encoder: - h264_mf
2023-03-28 17:36:32: MKAudioRecorder::Open: Device: {0.0.1.00000000}.{3fc9f6fc-77c1-450b-8f40-bdd8a5177f29}, File: C:\Users\micha\OneDrive\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled1_tempdir\audio_1_20230328_17-36-32.wav, Params: codec: 0, format: Sample Format 5, channel: 2, frame_size: 0, rate: 48000.000000, bit_rate: 0, quality: 0
2023-03-28 17:36:32: Probing to record audio from: Μικρόφωνο (Realtek Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 1
2023-03-28 17:36:32: Open audio device successes!
2023-03-28 17:36:32: flt sample format is not supported, s16 will be used
2023-03-28 17:36:32: MKAudioRecorder::Open: Device: {0.0.0.00000000}.{b85eabe7-0b33-4d5a-929e-349346bd4201}, File: C:\Users\micha\OneDrive\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled1_tempdir\audio_2_20230328_17-36-32.wav, Params: codec: 0, format: Sample Format 5, channel: 2, frame_size: 0, rate: 48000.000000, bit_rate: 0, quality: 0
2023-03-28 17:36:32: Probing to record audio from: Ηχεία / Ακουστικά (Realtek Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 1
2023-03-28 18:38:41: ActivePresenter 9.0.7 - 64-bit build. (Release Build: 2023.03.15) started
CPU Count: 4
Hostname: DESKTOP-1M8BFFT. Memory: 8,057 MB. Available: 3,483 MB. Memory Load: 56%
Disk Space: 230,799 MB (Free: 4,826 MB)
2023-03-28 18:38:41: TempDir: C:\Users\micha\AppData\Roaming\ActivePresenter\temp
2023-03-28 18:38:41: -----------------LISTING GRAPHICS DEVICES---------------------
2023-03-28 18:38:41: DXGIAdapter: Intel(R) HD Graphics 620 (0-76654)
2023-03-28 18:38:41: * \.\DISPLAY1 [0, 0, 1920, 1080], 1
2023-03-28 18:38:41: DXGIAdapter: Microsoft Basic Render Driver (0-81300)
2023-03-28 18:38:41: Selected DXGIAdapter: Intel(R) HD Graphics 620 (0-76654).
2023-03-28 18:38:41: --------------------------------------------------------------
2023-03-28 18:38:41: ---------------------LISTING AUDIO DEVICES------------------------
2023-03-28 18:38:41: Ηχεία / Ακουστικά (Realtek Audio) (API: Windows WASAPI, Input: 2, Output: 2, Rate: 48000, Loopback: true, Default Output: true, ID: {0.0.0.00000000}.{b85eabe7-0b33-4d5a-929e-349346bd4201})
2023-03-28 18:38:41: Μικρόφωνο (Realtek Audio) (API: Windows WASAPI, Input: 2, Output: 0, Rate: 48000, Loopback: false, Default Output: false, ID: {0.0.1.00000000}.{3fc9f6fc-77c1-450b-8f40-bdd8a5177f29})
2023-03-28 18:38:43: ---------------------LISTING WEBCAMS------------------------
2023-03-28 18:38:43: 1. Integrated Webcam - \?\usb#vid_0bda&pid_5769&mi_00#6&1ff99936&2&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
2023-03-28 18:38:43: --------------------------------------------------------------
2023-03-28 18:38:48: PrepareRibbonBar: 2028ms
2023-03-28 18:39:22: Checking updates for ActivePresenter v9.0.7…
2023-03-28 18:39:30: MKAudioRecorder::Open: Device: {0.0.1.00000000}.{3fc9f6fc-77c1-450b-8f40-bdd8a5177f29}, File: C:\Users\micha\AppData\Roaming\ActivePresenter\temp\rl_20230328_183930_a56k5hlfig.wav, Params: codec: 0, format: Sample Format 5, channel: 2, frame_size: 0, rate: 48000.000000, bit_rate: 0, quality: 0
2023-03-28 18:39:30: Probing to record audio from: Μικρόφωνο (Realtek Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 1
2023-03-28 18:39:30: Open audio device successes!
2023-03-28 18:39:31: flt sample format is not supported, s16 will be used
2023-03-28 18:39:33: Start capturing. Mode: Full motion. Capture Size: (1920, 1080)
2023-03-28 18:39:33: MKScreenRecorder::Open: Engine:2, File: C:\Users\micha\OneDrive\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled3_tempdir\video_20230328_18-39-33.mp4, Params: codec: 10001, format: NV12, width: 1920, height: 1080, color_range: 8, rate: 30.000000, bit_rate: 0, quality: 90
2023-03-28 18:39:33: Encoder: - h264_mf
2023-03-28 18:39:33: MKAudioRecorder::Open: Device: {0.0.1.00000000}.{3fc9f6fc-77c1-450b-8f40-bdd8a5177f29}, File: C:\Users\micha\OneDrive\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled3_tempdir\audio_1_20230328_18-39-33.wav, Params: codec: 0, format: Sample Format 5, channel: 2, frame_size: 0, rate: 48000.000000, bit_rate: 0, quality: 0
2023-03-28 18:39:33: Probing to record audio from: Μικρόφωνο (Realtek Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 1
2023-03-28 18:39:33: Open audio device successes!
2023-03-28 18:39:33: flt sample format is not supported, s16 will be used
2023-03-28 18:39:33: MKAudioRecorder::Open: Device: {0.0.0.00000000}.{b85eabe7-0b33-4d5a-929e-349346bd4201}, File: C:\Users\micha\OneDrive\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled3_tempdir\audio_2_20230328_18-39-33.wav, Params: codec: 0, format: Sample Format 5, channel: 2, frame_size: 0, rate: 48000.000000, bit_rate: 0, quality: 0
2023-03-28 18:39:33: Probing to record audio from: Ηχεία / Ακουστικά (Realtek Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 1
2023-03-28 18:59:26: Could not open project while capturing
2023-03-28 18:59:33: Could not open project while capturing
2023-03-28 18:59:41: MKScreenCaptureD2DImpl:StopCapture Frame: 5514, Drop: 0, Encoded FPS 4.576844, Captured FPS 4.577674, Time: 1204.541788s
2023-03-28 18:59:42: Recorded video data size: 40.7 MB
2023-03-28 18:59:42: ProcessRecordedAudio: duration (ms) 1205094
2023-03-28 18:59:42: ProcessRecordedAudio: duration (ms) 1203177
2023-03-28 19:00:38: Render Project Size: 1920 x 1080
2023-03-28 19:00:38: Threads Used: 1 / 4, Memory Available: 3,951/8,057
2023-03-28 19:00:38: Encoder: Windows Media Foundation - h264_mf
2023-03-28 19:13:24: Exporting video completed in 766 seconds.
2023-03-28 19:13:40: Opening project: C:\Users\micha\AppData\Roaming\ActivePresenter\backup\a0127a57-7917-409a-9f7c-b5dba2d84639.approj
2023-03-28 19:14:04: Encoder: Windows Media Foundation, Codecs: 10001 10002
