Problem: in my version 6.1.4, the touch “tab” is not known by the application in the training : When I use the training I create with atomi and I press the key “TAB”, nothing happen and I stay on the current slide
In ActivePresenter 6, if the Tab key is used for navigation among objects, it can’t be used for simulation. So please make sure that the Enable Keyboard Navigation option is disabled in case you set the Tab key for Key Stroke objects. You can find this option in Export To HTML5 Simulation dialog > General tab > More Options…
This limitation is completely removed in version 7: if there’s any active Key Stroke object with the Tab key set, the Tab is used for that object. Otherwise, the Tab key is used for navigation.
