Problem: To speed up testing of a presentation I want to be able to advance to the next slide and thought using a Key Stroke object could achieve that. However after inserting a Key Stroke object into the first slide, deleting the Correct and Incorrect messages which I don’t require and adding the Go Forward 1 Slide action to the On Correct event, I can’t see how to make it Show over Multiple Slides.
If I use Batch Operations to insert a Key Stroke object, then I have to go to each slide individually to delete the the Correct and Incorrect messages.
I just want a Key Stroke object with the same Correct Value on all slides.
ActivePresenter version: 7
OS: Win10
