Hello
it will be possible to avoid this popup that appears at the end of the report submission
if yes where and how
thank you very much John Nabo
Hello
Hi John
If you already provide another method to get the user id, or you don’t need to identify your users, you can add the following script to Project Properties > Event tab to prevent the pop up:
var userId = 'user id';
$.cookie('userid', userId);
Hi Toan,
Thank you very much for your quick response
Regards John
