Hi, I know that with ActivePresenter there is the possibility of inserting subtitles, but I wanted to ask if it is possible to import them already created in .srt format?
I thank you in advance.
Hi Fabio,
Yes, you can do that in ActivePresenter.
In the Insert tab, click the arrow on the Closed Caption button > From File… > Import To Single Slide or Import To Multiple Slides > select the file that you want to import.
Here is the tutorial for you to easily follow:
Quynh Anh
