I asked this question in an email last month.
When I set up an answer button interaction, the “+” when setting the second answer button is always unclickable, and I need to close and open the project to set it again. In short, only one button can be set to open a project at a time. How should this be resolved?
Please share your project so that we can check.
Do you mean that each time you open the project, you can only add event-actions to just one object?
If so, we can’t reproduce the issue in our tests.
Can you please share a short video that demonstrate the issue?
P/S: Please consider carefully before sharing your projects publicly as they may contain confidential information. Next time, you can send to our support@atomisystems.com.
Thank you for sending the video.
It seems that this issue only occurs when Properties pane is floating and it’s closed after adding event-actions for each object.
We’ll try to find out the root of the issue and fix it in the future.
Now you should dock Properties pane on the right edge of ActivePresenter to prevent the issue.
