When installing AP, it installs on a Network drive and not the C drive. There was not an option to select or change where it will be installed.
How do I get it to install on the C Drive/ Program folder?
Hi Liz,
If you want to install ActivePresenter in another location, please restart your computer, uninstall the app and install it again.
Best regards,
Hang
That worked! Thank you
