You have a way to import PowerPoint Slides into a project. I think it would be helpful to also have a way to import slides from one ActivePresenter project to another. It would be much better than having to copy and paste slides.
Hi Terry,
ActivePresenter has already had this feature. To import slides from one ActivePresenter project to another, In the Home or Insert tab, click the arrow on the New Slide button, then click Slides from ActivePresenter.
For more information, please take a look at this tutorial: https://atomisystems.com/tutorials/ap8/how-to-insert-slides-in-activepresenter-8/
Best regards,
Hang
Thanks for the info.
Your online help section directs you to copy/paste each of the slides from one project into another. https://atomisystems.com/tutorials/ap8/copy-cut-and-delete-slides-in-activepresenter-8/
