Is it possible to import via CSV a rating/likert question?
Unfortunately, rating/likert question is not supported to import via CSV.
We will add this feature in our TODO list and try to implement it in the future release.
At the current version, supported question types include True/ False, Multiple Choice, Multiple Response, Fill in Blanks, Drag-n-Drop, and Fill in Text Entry.
You can take a look at this article for more information:
Thank you, I appreciate this being added to the ToDo list.
