Images auto resizing
Problem:Problem: The resizing handles wont allow me to resize my image, when I move it the image enlarges and I cant resize. This worked fine for me a couple of hours ago.
ActivePresenter Version:
OS:
It seems that you move the image into a flex box accidentally. To avoid it, you can press Alt while moving an object on Canvas.
You can also turn off the auto snapping feature: View > Container Snapping.
Thank you for your help. That worked perfect for me.
In addition, to make one or more objects excluded from the slide container layout, you can select them
first and then do either of the following:
● Right-click the objects > Exclude from Container Layout.
● Go to the Properties pane > Interactivity > General > select the Exclude from Container Layout check box.
