I have an image that is hidden from the start of the timeline and connected to a drag and drop. Upon correct the image shows.I want this image to show for the rest of the presentation after it has been triggered on. How can I do this?
You just need to follow the below steps:
- Right click the image then select Show over Multiple Slides > Top Layer.
- In the On Correct event of the drag-n-drop question, add a Show Object action.
- Select the image and deselect the Hide After option in the option list of the Show Object action.
If it is not your case, please share your project with us at support@atomisystems.com so we can check.
