How can I type in the size in Pixels for an Icon? Dragging it changes the size, but if I want exactly 50x50 pix, where to I type this in? I can’t see this in properties.
For example, if I insert another different icon, and I want to make sure both are the the same size? Also, are there gridlines on the slide so I can position and align things to grid?
ALSO: How can I Flip an object or Icon 90 degrees vertically or Horizontally?
For example, there is no Left Arrow Icon. I can insert a Right Arrow, then I should be able to flip it horizontally so it becomes a Left arrow.
To change the size of Icon, Shape or any object, first, select the icon > Properties pane > Size & Properties > Transform > adjust values of Width and Height by entering values in those spin boxes.
To rotate the object, along with dragging the rotation handle of the object, you can enter a value
in the Rotation spin box.
ActivePresenter currently allows users to flip the image only.
To do that, right-click the image > Edit Image… > choose a flip command in Tools.
We will add the Flip feature for objects in the upcoming version.
