My goal is to generate text to speech and playback MS audio for Zira. The attached image shows my steps, not sure why i cant hear anything when I click Speak in the settings, that feature is to hear the audio that will be applied to the given text, no? Any advice much appreciated.
Hi William,
As the screenshot you provided, there are two output devices in your computer. Therefore, the audio might play in the secondary speaker. This problem might happen when you plug/unplug new headsets while using ActivePresenter. To avoid this problem, you should plug all microphone/headset devices before start ActivePresenter.
And about step 4: Please don’t worry about Input Device because you’re using text-to-speech not recording.
