Problem: I want the user to only right-click on the object on the current slide to go to the next slide. I cannot find the option to use either left or right-click. Both clicks are working.
ActivePresenter version: 8.5.4 - 64-bit build. (Released: 2021.11.18)
OS: Windows 10
You can add the Mouse condition for the Go to Slide action when the user clicks on an object as image below:
Regards, Tuyen
Worked as expected.!
Thanks Tuyen for quick response.
