Problem: How to resize an object around its center point?
Saola Animate version: 2.7.1.
OS: Win10 (64-bit).
Many drawing software provide hotkey to do this,
like hold on the [Ctrl] on the keyboard,
then drag the control point to resize an object around its center point.
But I don’t know how to do this on Soala Animate, please help.
Your scale Tool (specially Rotate, Scale, Rotate view) are so fancy,
suggest you provide slider for them,
so user can drag the slider to adjust their value.
or let mouse scroll button or keyboard up | down arrow to adjust them.
You can use the up / down arrows in the transform boxes to quickly / accurately change these settings and also the scroll button on your mouse, with or without the CTRL modifier key to achieve the same thing.
