I have several presentations (lectures) in a course. After I output my first presentation to HTML5 (tutorial only), the file name is tutorial.
However, when I want to output my second lecture to the same folder, it over-write the first one completely.
Can I put all the HTML5 output of all my lecture into same folder so that my students won’t miss out one of them?
Thanks
You can select the Settings option in the output location, then specify the Project Resources and File Name Prefix options (ex : resources_L1 and L1), the other options are shared between projects so you don’t need to change theme.
Thanks. The player name can be remain unchanged since all file can use the same player, right?
Yes, you’re correct.
Great! Thanks. I have done it!
