I have started to use ActivePresenter for recording screencasts of my lectures and have the following question:
How can I correct parts of my video after recording if I am, e.g., not satisfied with my explanations?
I have gone through the tutorials and information on the web site, but could not find a good solution.
My first idea was: Record a second (short) video with only the corrected explanations. Then go to the first video and delete the faulty part, afterwards copying and pasting the corrected part to video 1 at the position where I have just deleted the faulty part.
But: This does not work, since “pasting” does not insert a video at the given position, but rather creates two new streams (audio and video) in parallel to the existing ones! I simply want to replace one video/audio piece by another one.
Could you possibly help me out? What is an easy solution to my problem? The only idea I had is: create some “blank” time in the original video 1 which is exactly as long as the new video part, then paste the new video part 2 to the right position in video 1. But I am sure there is a better way, right?
ActivePresenter Version: 8.0.3.
OS: Windows 10.
