I would like to let you know that I am already using the most current version of Active. However, I can not control the volume separately. For example, leave a song with low volume and video with loudest volume. When you change the effect it applies at all. What do I do?
Hi Romaryw,
I guess that you change the playback volume, so it applies for all audio/videos.
Here is the tutorial about how to change audio volume:
Thank you! I had managed to sort it out. That’s what you said. Now another problem that I am this is. Do you know if you can change the color and brightness of the video in this program?
Hi Romaryw,
Unfortunately, it isn’t available in the current version of ActivePresenter yet.
A pity, because some programs much simpler already has this function, even APP for Mobiles. But okay, I know that in future they will put this function. I’m enjoying the program. Thank you. Hugs
