Problem: Audio is not completed.
I have an action added to the audio of this slide. It looks like the ‘on ended’ action prevents the audio from being played completely.
Thanks!!
ActivePresenter version: 9.0.6
OS: Windows
Thanks!!
OS: Windows
Hi Koen,
First, please make sure that you click to unmute the audio since muted autoplay is always allowed in most modern browsers. (Autoplay policy in Chrome - Chrome Developers)
Second, the slide’s duration is greater than your object’s duration (Text English transition).
If you have tried the above methods but they haven’t helped, kindly send your project and its external data folder named PROJECT FILE files (if any) to support@atomisystems.com so that we can check.
Best regards,
Hang
