How can I add more than one true or false question on one Quiz slide with one submit button using Active Presenter 7
OS:
Windows 10
OS:
Windows 10
ActivePresenter doesn’t support this case directly since it is difficult to manage content. You will need to create separated question slides, then copy their contents and paste into a slide. Can you please tell why do you want to do this?
You can use Two Content layout instead of Question layout to add 2 questions on each slide. Please follow below steps to do that:
If you want to add more question or custom slide layout, please take a look at this tutorial https://atomisystems.com/tutorials/ap7/use-slide-masters-in-activepresenter-7/. By customizing Slide Master you can define your custom layout then use it for inserting slide.
Hope this will help.
