How can I make it appear as a checkmark when the Radio Buttons in the Multiple choice question is checked? I want to achieve a result like this picture.
Hi again,
Unfortunately, there is no direct workaround for you to achieve this.
We currently support the built-in radio styles as follows:
BR,
Quynh Anh
Hi again dear Quynh Anh,
Thank you. There is a setting screen called State View. Is it possible to make a change here?
Hi again,
You can make a change here but it’s quite time-consuming as you need to design the checkbox as you want first.
Then, you can click the Edit States icon and follow the instruction in the video below to change the buttons:
Kindly notice that there are more settings for you to do with the buttons so you can take a look at the Format tab as in the image when clicking on the button:
Best,
Quynh Anh
Thank you very much.
