When you create a hotspot over an image, this hotspot is unable to maintain it’s position, rendering hotspot questions impossible in a responsive project.
Thanks for reporting the problem. You should set the dimensions of both the image and the hotspot to relative value (% value) to overcome this issue. However, this will lead the aspect ratio of the image changed.
We will improve it in the future releases.
