Would it be possible to hide/mask the keystrokes of text box which are being used for sensitive fields.
for example when a user logs in. the user enter her/his user-id but the subsequent password text box should be masked with say **** ?
You just need to select the Text box and check the property “Password field” on the property pane.
Thanks ! Very much appreciated
