I am developing a distance learning course with step by step interaction with the user.
What I need is:
When the student does one of the steps they are being asked to be marked on the list.
I even managed to do it and it is working however for a course with many slides is impossible to use this way.
I’m using the slide master
You can add the following script to On Load event of master slide to change checkbox state:
var currentSlideIndex = prez.currentSlideIndex();
var i;
for (i = 1; i < currentSlideIndex; ++i) {
var visitedCheckBox = prez.object('check_' + i);
if (visitedCheckBox)
visitedCheckBox.state('Estado certo');
Slides inserted after that will inherit this On Load event-action.
For existing slides, you must copy this event-action and paste to each slide event-action.
Please see this attached sample: Teste.approj (2.8 MB)
