Hi, I’m new to this program and thanks for your help!
I tested some recordings with the microphone but wanted to record internal sounds, so I selected the other option from the sound input menu. The green square appeared so that I could set screen size, but no recording seemed to start. Active presented became unresponsive. I tried uninstalling it then reinstalling the program but I get an error message saying Active Presenter shut down after launching it.
The error is Activepresenter.apconfig couldn’t be removed
Thanks so much for your help- am panicking as needed to record something and have already messed up the program!
