Problem: Hi, in the former version (6) it was possible to group slides in the table of contents. I don’t see were I can do the same in this version. In the property pane, there is the slide name but the field/property that was to be completed with the groupname has disappeared. Can you tell me were to find this? I checked the user manual but didn’t find it. Thank you.
ActivePresenter Version: 7.2.3
OS: Windows 7
