Problem: Hi, Is it possible to have global variables that are used by multiple JS-codes activated by different events? I want to use the same array over multiple slides. Seems like the non-JS-part of AP does not support arrays. Thanks
ActivePresenter Version: 8
OS: Win10
Hi Rolf,
You can assign it as a proprty of prez object. For example:
prez
\\ in a event prez.myVar = [1, 2, 3]; \\ in another event console.log(prez.myVar.join());
Thanks, Toan, that helped a lot.
Best, Rolf
