Hi Team,
Please advise how the Correct, Incorrect and other pop up messages boxes can be edited.
It looksl ike I can edit radio buttons, questions area etc., but I cannot edit the messages.
It was possible in Version 6.
P.
In some built-in themes in ActivePresenter 7, those default Correct, Incorrect messages are placed in the Slide Master, you can edit them by selecting View tab > Slide Master and then select the Question Layout and make changes.
Of course, you can insert your own messages by Right clicking the question (Interaction, in general) and select Insert > XXX Message from the context menu. These messages can be edited normally right in your slide.
Thank you. I followed your advice.
